Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CallManager 4.2 User Directory/AA Issue: Username Change
I have a CUCM 4.2 Pub/Sub setup and my client had an employee leave and they hired a replacement at the same extension.
I made all the appropriate changes to the system but now if someone tries to dial by last name the new username is not found.  Dialing the old ex-employee name still works and will connect you to the new user.
There are no traces of the old username on either the pub or sub.
Am I missing something?
Thanks in advance!
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CallManager 4.2 User Directory/AA Issue: Username Change
H there,
The relationship for AA to User is usually built in
Unity/Unity Connection/CUE not within Callmanager itself.
What are you using for VM/AA?
Cheers!
Rob
H there,
Cheers!
Rob
We're using Unity Connection.  I didn't think of that angle...
Let me take a look....
That was it.
I guess I'm too anxious for the end of the day on Friday.
Thanks!
You and me both
Have a great weekend!
Cheers!
Rob
180
