Community Member
CallManager 4.2 using BAT tool
Hi there,
I'm trying to insert phones using BAT. I created a template. Now I'm looking for the "Excle Sheet". Where I can find/download that BAT.xlt?
Thanks.
1 ACCEPTED SOLUTION
Highlighted
Re: CallManager 4.2 using BAT tool
C:\CiscoWebs\BAT\ ExcelTemplate\BAT.xlt
or simply open a windows explorer and use the find feature looking bat.xlt
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
Highlighted
java
java
155
