CallManager 4.21 and 7921 Wireless IP Phone
Does anyone know if a Device Pack is required to use the 7921 with CCM ver. 4.21? I see where the phone is supported but need to know how to discover if a Device Pack is required. It's for an upcoming project and can't access the servers.
Thanks!
Re: CallManager 4.21 and 7921 Wireless IP Phone
Here is the link to the compatibility matrix:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp94276
Scroll down to Table 51 for the 7921 compatibility.
Hope that helped.
Please rate helpful posts.
No help, already saw that. Turns out you need 4.21 sr1b, install a Device Pack 4.21.06 and then install a firmware load.
Thanks! Oh, I work for ATT, too!
123
