Community Member
Callmanager 4.3 receiving drop calls
Can you please help me. I have call Manager 4.3 running in a Cisco 3825. For some reason my system started to receive calls from Unknown number and when it is answered theres nothing there or the call drops before it is answered.
Can someone please help.
You'll need to run some debugs to find out the specific cause for the disconnection.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
Can you please suggest some debugs i can use.
It all depends on what kind of connection you use for the PSTN.
java
java
107
