CallManager 4.x and CME Intercluster
znaqvi
I have Central site running CallManager 4.0 on MCS7835.
I also have CME running on remote site. Are there any issues doing intercluster trunk between CCM and CME?
5 Replies 5
paolo bevilacqua
Hello znaqvi,
I can tell you something from the CME perspective. It does not have the concept of cluster at all. It will just use the configured voip dial-peers to reach the remotes via h.323 or SIP. It will use an h.323 gatekeeper or SIP proxy if so configured.
Yap Paulo is right, and for the CCM side you add an ICT (Inter Cluster Trunk) IP adress points to CME and you create then a Route Pattern pointing to the ICT.
this should work perfectly.
Good day
kelvin.blair
Level 5
Level 5
You can configure the in CM has an h.323 gateway. Send calls to CME from CM via route patterns and that gateway. You can setup VoIP dialpeers and point them to CM. Since you added the gateway as an H.323 gateway in CM calls will be accepted or else rejected. One thing I suggest is add the following statements in the CME Global config.
voice services voip
allow connection h323 to h323
allow connection h323 to sip
allow connection sip to h323
allow connection sip to sip
h323
sip
I have done all that...
and the calls from the CCM to the CME is working great...
however, i am having trouble calling from the CME to the CCM,
i have configured the router with the following voip dial-peer
dial-peer voice 1 voip
destination-pattern 91...
session target ipv4:<>
dtmf-relay h245-alphanumeric
i get a busy tone...
Ahmed,
Make sure you have
int fa0/0
h323 voip gateway-interface
h323 voip bind srcaddr
This IP address should match with the ICT that you create in Callmanager.
Sankar
PS: please remember to rate posts!@
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
