Callmanager 4.x user table
Hi All,
I am planning to upgrade 4.x to 7.1. I don't want to use DMA for this migration because I want to do fresh installation. Although, I need users, phones, extension, DID info from 4.x server. So I think I have to use SQL query analyzer to query database from user table. would you please send the instruction how to query from DB and pull out all users information?
very appreciate
Alex
Re: Callmanager 4.x user table
user info is not on CUCM DB, that's why it's CUCM DB. user info is on the directory whichever you're using
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks for the quick respond, but Callmanager 4.0 is not installed in Active Directory. If you show me how to query from its local DB, I'd be very appreciated.
Alex
then you're using DC directory, log in there and you'll get the info.
java
java
I am trying to login to "DC Directory Administrator" with username and password as CCM admin account, but it doesn't let me in. What user should i use to login to this application?
sorry about too many qustions!
thanks
Alex
user Directory Manager
java
java
hey,
use BAT to export users and phones
you could look at AXL SOAP to retrieve all information as well
sorry again,
how can I find this user? I search through CCM and local user in the server but I can't find it.
thanks again
Alex
195
