Community Member
CallManager 5.1.2 Disk Usage 100%
Hello everybody.
I have a customer with a callmanager version 5.1.2.3000-2, this callmanager shows from Operating System Administration its disk 100% used.
The CAR gives an error, if I want to loggin, I'm not able to active all the services for CDRs.
I enclosed a capture from OS page.
Does anybody have an idea of it?
REGARDS.
ANY HELP WILL BE VERY APRECIATED
WALTER
Re: CallManager 5.1.2 Disk Usage 100%
try deleting all the traces you have using RTMT, if still no avail probably you'll need a TAC case so they can get root access and delete unused info
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Hi Javalenc,
How can I use RTMT to delete such a trace as I had surfed servicablility available options and I did not find any related thing.
Mo
Green
when you are colecting traces you will get a delete files from server option (last screen)
You can start creating a remote account before opening a case with us
134
