06-05-2007 09:42 AM - edited 03-14-2019 09:53 PM
I have installed the callmanger 5.1; and installed the DLU as well but i cannot activate the callmanager service ...
06-05-2007 10:12 AM
DLUs are for phones. You need to install one node license per every node for CM service to be up and running. If you have a pub and sub, you need two node licenses.
HTh
Sankar
PS: please remember to rate posts!
06-05-2007 10:19 AM
Thanks for the reply... what is the procedure to buy node license ? It Does not come with the purchase of callmanager server ?
06-05-2007 10:36 AM
You need to get a node license according to the server you have. If you have a 7835, you ll need LIC-CM5.0-7835-H1= (for a HP server).
Sankar
