Community Member
CallManager 5.1 DHCP
Sorry if my question is quite basic, but how can I check the current DHCP leases under CallManager 5.1? I have a suspicion I have exhausted one scope.
Thanks in advance,
Paul
Bronze
Re: CallManager 5.1 DHCP
For this requirement use the command " show network " with parameters. for more information refer the following url,
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008079bbfa.html#wp1026032
Silver
Anyone have an answer to this? I tried every show network command to no avail.
Probably not the answer you are looking for, but unfortunately as far as I know you are unable check the dhcp bindings using the administrator CLI access, this can only be done using the root username and password which only TAC can help with. :(
Allan.
Silver
Alan,
Thanks for the (non) answer. :) If it turns out to be true, then there is no good reason to use the DHCP server in CUCM. There's probably a perfmon statistic somewhere, but I don't know of any documentation on any (ok, very few) of those values. I'll check around RTMT to see if there is anything of value there.
Afrankel:
CallManager (Communications Manager) 6.0(1a) in my case is configured as a DHCP server (DHCP Monitor Service). I want to determine what clients (Phones) got what IP addresses from the DHCP server.
159
