Callmanager 5.1 fxs issue
norm.trees
I have a cucm cluster running 5.1.
Have just installed a new 2851 voice gateway which works fine. Have added a vic3 2fxs did card, I had to find a new IOS to be able to see the card, but this is now ok.
However, when adding this to cucm, there is no vic3 2fxs did card to choose under the gateway options.
This would appear to be a new card type, are there regular updates that I can apply to the cucm to be able to support this new fxs card. If so, I have been unable to locate one as yet.
Hope you can help
N
Marwan ALshawi
the gateway MGCP?
yes the Gateway is MGCP.
N.
