Callmanager 5 and enhanced dsp conference bridge
I am trying to add a hardware conference bridge on a callmanager 5.1 using a 2801 . I have it all configured and when I try to add the ios enhanced CFB in callmanager I get a cc_register_failed
what am I missing..
ios og 2801 is 12.4.13t
Hall of Fame Super Silver
Re: Callmanager 5 and enhanced dsp conference bridge
When you build the CFB SCCP identifiers what CM version do you specify?
Chris
I am facing the same pblm using 2851 with 12.3(11)g.while giving the SCCP identifier command i cant find any ccm 5 version .I think i hav to upgrade the IOS,if wrong plz correct me
You can use the the 4.1 identifier and it will work just fine.
Chris
For what it worth, this the the config I'm using and it works perfectly fine. This is a 3845 running 12.4(11)T1 and I run CM 5.1
voice-card 0 (whatever board you are using)
dspfarm
dsp services dspfarm
sccp local GigabitEthernet0/0
sccp ccm X.X.X.X identifier 3 (I don't use version numbers and it works perfectly fine. I believe it actually defaults to 3.1)
sccp ccm X.X.X.X identifier 1
sccp ccm X.X.X.X identifier 2
sccp
sccp ccm group 1
description Local conferencing
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
associate profile 1 register CFB0013c34d4d90 (This is the mac of my interface. It could be anything. But this must match the device name in callmanager)
registration timeout 3
connect interval 60
switchback interval 60
dspfarm profile 1 conference
description Local Conferencing DSPs
codec g711ulaw
maximum sessions 4
associate application SCCP
Todd
IOS version in ur router is 12.4(11)T That makes the difference.For enhanced conference
in 2800&3800 using PVDM2 needs minimum IOS version of 12.3(11)T
131
