Callmanager 5 and Unbity
Does anyone know for sure what version Unity works with CM 5. There are lots of references to tested with 4.2 Unity but the matrix says it is a TSP version 8.? that is the factor. Can anyone tell me for sure if 4.0.5 will work with callmanager 5.1.
1 REPLY
Re: Callmanager 5 and Unbity
Although I have only integrated a 4.2 system with 5.1, only the TSP version should matter. Look at this link.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cutspmtx.html
As long as you use 8.1(3) or 8.1(2) TSP you should be good to go
Sankar
PS: please remember to rate posts!
87
