CallManager 5 + Skype
Anyone knows whether a CCM 5 and Skype integration is possible???
Is anyone using Skype2Sip??? Can it be integrated with CCM??
mchandak
Level 7
Level 7
Haven't used it, I've heard it does work. You would need a SIP Trunk from Skype and add it to CM as SIP Trunk/Gateway
dperfett
Hello Ioannides,
yes this works. skype and ccm/ccme is feasible with an ip skype gateway (supporting SIP or H323).
check more info here:
http://www.stonevoice.com/Products/IPSkypeGateway/tabid/989/Default.aspx
rgds,
