Callmanager 5.x , 66 % memory Utilization
Hi All ,
i am using  callmanager 5.x , memory utilization reaching upto 66 % .
is that normal for publisher server ?
what could be the reasons to make memory Utilization High .
we have 2 servers  MCS 7835( PUB & SUB)
Re: Callmanager 5.x , 66 % memory Utilization
Linux platforms by default try to use as much memory as available
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi ,
i am sorry , i couldnt not understand .
you want me visit below link and open case ??
please advise .
Bronze
Hi ,
What java is saying is that you don't need to worry.I have seen callmanager 5.x with very high mem utilisation and be quite happy.There are quite a few bugs with memory leaks in the older versions of 5.x but unless you have a problem i would ignore it.
mark
Indeed, if you have ever worked with Linux platforms you'll know this is the default behavior. They always grab as much memory as they can to avoid using the HDD.
Aslam: Matt already told you this, but if you need help, you need to open a case. DO NOT reach our mailers directly for non-program related questions.
If you don't have access to PDI then reach TAC or your SE.
java
java
194
