CallManager 5.x LDAP Integration - Can you specify defaults?
With LDAP integration in CallManager 5.x, when user information is synchronized to the CallManager server, is there a way to create a template or set defaults for new users that appear after a DirSync operation? Specifically, I am trying to find away to assign all users that are imported from LDAP to a default User group, as well as assign a default PIN.
I haven't found a way to do this in any documents or in the service parameters. Has anyone found a way to do something like this?
1 REPLY
Re: CallManager 5.x LDAP Integration - Can you specify defaults?
Hi Jeff. I have same problem. I tried to find some solution how to automaticly assign default parametrs to new users after import from LDAP. Typical issue is, as you said, to move new user to user group. Unfortunatelly I did not find any solution :o( If you will fix this issue, please share you solution with us..
REgards Miroslav
176
