Callmanager 6.1.2 and Callmanager 8.62a
patcbr600
Hi all,
Hi have a CUCM cluster with version 6.1.2 with a ICT trunk to a CUCM 8.62a, i'm not able to place call betwen the two cluster, i have signalling but when i try to anwser the call is disconnected. After seeing the traces we found that CUCM 6.1.2 is sending a release complete and in the traces from 8.62a we see the folowing incoming msg:
18:12:49.393 |ViprUtils: Number has no +, not a valid E164 [57174]|1,100,150,1.5702^172.17.16.3^*
Since CUCM 6.1.2 does not support the + digit how is giving this error ?
patcbr600
Jaime Valencia
You're configuring a "regular" ICT between them right?? not selecting any special use on 8.6.
If signaling works fine (phone rings) the I'd suspect a codec issue.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
