Callmanager 6.1 trunk with Skype
Hello everybody,
I create this discussion because I need to set up a trunk on callmanager 6.1 and skype connect, I have the The ID and the password from skype, and skype it's pointing to the Cisco Callmanager IP, for some reazon the trunk is only giving me a bussy tone, can any body provide a guide to set up the trunk with skype with the specific options that I have to activate on Cisco callmanager 6.1, cause I already configured the trunk but I think something is missing.
Thank you in advance,
Andrew.
Re: Callmanager 6.1 trunk with Skype
Since you need to use authentication with sip trunk then it us better to use a cisco router in between and configure it as a CUBE
Cucm -
sip--cube--skype
Hope this help
If helpful rate
Blue
Hi Andrew,
Skypee Connect is not tested by Cisco, So we do not support it officially. The reason being it is not recommended for toll  quality voice replacement because QoS is not guaranteed.
However We have seen this has worked. But Since  it is not tested, Cisco TAC will not be able to help you on  troubleshooting any problem which you may face in the production.
Tested third party SIP integration as as below
http://www.cisco.com/en/US/solutions/ns340/ns414/ns728/networking_solutions_products_genericcontent0900aecd805bd13d.html
And as said above , You will need CUBE in between CUCM and Skypee Connect to make it work.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
1137
