callmanager 6.1 with NM-HD-2VE=
ggittins
after an upgrade from ccm 4.1 to 6.1 i noticed that my conference resources were not registered here is the running configuration question do i need to upgrade the ios ?
also where can i find the link to configuring sccp the old way and the new way?
sccp local FastEthernet0/0
sccp ccm 10.10.11.65 identifier 2 version 4.0
sccp ccm 10.10.11.64 identifier 1 version 4.0
sccp ip precedence 3
sccp
sccp ccm group 2
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 2 register sat-vgw1-card2
sccp ccm group 1
associate profile 1 register sat-vgw1-card1
9 Replies 9
Jaime Valencia
take out the version 4.0 from:
do a no sccp and then sccp
javalenc
if this helps, please rate
java
this is what i get
SCCP Admin State: UP
Gateway IP Address: 10.10.16.32, Port Number: 2000
IP Precedence: 3
User Masked Codec list: None
Call Manager: 10.10.11.64, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 2
Call Manager: 10.10.11.65, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 1
SCCP application services(dspfarm profiles) are not enabled
or haven't associated to SCCP CCM group
sccp ccm 10.10.11.64 identifier 2
sccp ccm 10.10.11.65 identifier 1
sccp
sccp ccm group 2
sccp ccm group 1
Can you check "show diag" to see how much DSP resources are actually installed there ?
what IOS are you running?, maybe it is old and you would indeed need an upgrade
at least most of the times i have tried that WA has worked just fine when taking the version
javalenc
java
is there a compatability list for module with callmanager 6.1
Ignore, posted in error.
question for users using version 6.1 or 5.1 what version do they select on the sccp
Hi  javalenc you are the best voice eng and i am your big fan,why dont you add me as you student so that i can learn lots of tech and solution and i can gain lots of knowledge from you...coz every post of yours and solution posted  worked for me all the time...thank you so much....If you dont mind can i get your mail id please.....
