Callmanager 6.x how to offload CDR flat files
How do we offload CDR flat files from Callmanager 6.x.
Mudassir
Re: Callmanager 6.x how to offload CDR flat files
Configure a billing server
java
if this helps, please rate
java
www.cisco.com/go/pdi
My situation is we dont have a bill server right now, its under planning.
But I dont want callmanager to overwrite the CDR flat files.
Till I get the billing server, I want to offload CDR flat files and store it somewhere.
Mudassir
You don't necessarily need an actual billing server, this sends the files via FTP to a server.
The other option is to do this via CLI one file at a time... and you still need an FTP server where to send the files.
java
java
I was looking for something like we did in Callmanager 4.x.
Create a DOS bat file and copy all the files from CDR directory to a FTP server.
Is there a procedure like this for Callmanager 6.x.
Copying one file at a time is painfull.
Mudassir
Yes, that's why the option is the billing server which send this automatically.
You cannot install or create any scripts on the server, maybe run the script somewhere else and send the instructions by ssh session. I'm not a programmer so i'm not even sure if it's possible.
java
java
181
