08-10-2009 01:25 AM - edited 03-15-2019 07:16 PM
Hi all,
I'm having the folowing problem with sip calls:
When i try to call from cisco callmanager to a GSM sip gateway the callmanager never send the ack to a status 200:ok messague that is send from the gateway to the callmanager and since i dont have early-media configure the the sdp is never send from the callmanager to the gateway. The flow for the messages is the folowing :
CM to GSM-Gateway
INVITE->
<-TRYING
<-RINGING
<-SDP-STATUS:200 OK
<-SDP-STATUS:200 OK
<-SDP-STATUS:200 OK
<-REQUEST:BYE
STATUS:200OK ->
Since the ack to the status 200 OK is never send the call is never stablishes
Does any one have an ideia
08-10-2009 03:32 AM
Hello all.
Pls i need your help, I have a UC520 device and my IP phones 521SG and 524SG Phones are not communicatiing with it. My IOS is 12.4 and CME version is 3.0.
Kindly help.
08-10-2009 03:39 AM
Are the phones register with the CME ?,
08-10-2009 06:26 AM
Pls explain wat u mean?
Also wats the diffrence between Cisco Unity Express and Communication manager Express.
08-10-2009 04:15 AM
You need to be on 12.4(20)T or 12.4(11)XW7 or higher for the CP-500 phones to register.
-nick
08-10-2009 06:31 AM
Thanks Nick,
I use 12.4(11)XW7 and its not registering.
My phones are 524SG,521SG and SPA525G.
I use cisco unity express 3.0.
08-10-2009 03:29 PM
I think it may be XW8. Trying to find original release, but cannot find the IOS required for these.
-nick
