CallManager 7.0
Can we do an upgrade from CUCM 4.1(3) to CUCM 7.0? Are there any reference material for the upgrade path for CUCM 7.0?
Re: CallManager 7.0
Jays,
Upgrade Paths to Cisco Unified Communications Manager 7.0(1)
These sections contain information about upgrading to Cisco Unified Communications Manager 7.0(1).
Direct Upgrade
You can upgrade directly to Cisco Unified Communications Manager 7.0(1) from
•5.1(3)
•6.0(1)
•6.1(1)
•6.1(2)
Upgrade by Using Data Migration Assistant
You can upgrade to Cisco Unified Communications Manager 7.0(1) via Data Migration Assistant (DMA) from:
•4.1(3)
•4.2(3)
•4.3(1)
•4.3(2)
From this good doc:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_0_1/cucm-rel_notes-701.html#wp579989
Hope this helps,
Met.
Hall of Fame Super Red
Re: CallManager 7.0
Hi Jason,
Here is a little more to add to the good tips from Met (+5 points Met :)
Upgrading to Cisco Unified Communications Manager Release 7.0(1) from Cisco Unified Communications Manager 4.x Releases
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/7_0_1/upgrd701.html
Data Migration Assistant User Guide Release 7.0(1a)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dma/7_0_1/dmaug701a.html
Hope this helps!
Rob
Re: CallManager 7.0
Thanks Guys!!! This helps me a lot...
285
