Callmanager 7 search
is there any easy way to search for all phone numbers that are assigned to a specific calling search space? I don't care if it's through a search or an export, I just need to verify what numbers are assigned to a particular calling search space
thanks
-Brian
Everyone's tags (2)
1 ACCEPTED SOLUTION
Silver
Re: Callmanager 7 search
Under related links, you can chose Dependancy Records. This will provide a list of DNs or patterns that
are associated with this CSS.
You can do an export all details using BAT and then just order by the CSS field in a spreadsheet editor.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
could you be a little more specific? on the 'bulk administration' tab, I didn't know where to go from there. Just to be clear I have phones profiles in CSS, ext. mobility profiles with lines in CSS, and phones with assigned lines in CSS.
Brian,
Just to confirm, you're interested to find directory numbers with a partiticular Calling Search Space assigned at the line/DN, not a list of DN/Partitions that are contained within a particular CSS.
If it is the former, the following sql query can be used to find DNs that have been assigned to CSS :
run sql select dnorpattern from numplan n, callingsearchspace c where n.fkcallingsearchspace_sharedlineappear = c.pkid and c.name = ''
This query should work in 6.x and above.  You can change the name to match the CSS name of interest and give it a shot.
-jt
right, all directory numbers with a particular CSS
I have never issued sql commands to call manager, to do that, do I need to install a plugin? "application"-->"plugins" ?
Super Bronze
Just connect to the server via SSH using Putty or a similar client, and paste in the 'run sql ...' line as a command. Set Putty to log printable output to a text file, and you can then import the text to Excel as a .tsv file for further manipulation.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Silver
494
