CallManager 8.5 LDAP Custom Filters
I want to synchronize all users except 52101.  We sync to ldap based on IpPhone field and objectClass =user.
Is this the correct LDAP Filter to exclude 52101 ?
(&(ipPhone=*)(objectClass=user)!(ipPhone=52101))
Is this the correct LDAP Filter to exclude 52101 thru 52103 ?
(&(ipPhone=*)(objectClass=user)!(ipPhone=52101)(ipPhone=52102)(ipPhone=52103)
Reference
https://supportforums.cisco.com/thread/2004812
http://technet.microsoft.com/en-us/library/aa996205%28EXCHG.65%29.aspx
Everyone's tags (5)
1 REPLY
I believe it will look like this:
(&(ipPhone=*)(objectClass=user)(!ipPhone=52101))
If you refer to the link below, you'll see the ! goes inside the ( )
http://msdn.microsoft.com/en-us/library/aa746475%28VS.85%29.aspx
Hope this helps!
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
1471
