CallManager and Dial-peer
I'm not sure how to ask this question but here it goes...
We are running CallManager 7.0 using route groups, route list, and route patterns (I assume that this is considered a dial plan).  Calls go through our 3845 router (voice gateway) to the PSTN.  There is some configuration statements in the 3845 router which refer to dial-peer.  What are these statements used for?  Doesn't CallManager handle the call routing or am I wrong here?
This is Video Over IP, please
This is Video Over IP, please move this to the right area.
CUCM only takes care of the dial plan by itself if using MGCP, if using H323 or SIP, the GW also requires the dial plan logic for inbound/outbound calls. If you search dial-peer on cisco.com you'll find plenty of documentation on them.
java
if this helps, please rate
www.cisco.com/go/pdi
We are using MGCP so, does
We are using MGCP so, does that mean if we change the dial-peer configuration on the router it will not  have any affect on our current call routing?  We want to test a Microsoft Lync connection using the router.
I would assume that if you're
I would assume that if you're using it with MGCP, and have dial-peers, you might have SRST configured. Or something else might be using it for H323. Make sure no one is using that config before changing anything.
java
81
