Community Member
Callmanager - Append + to outbound call CID?
Is it possible or is there a work around to append a + before the 10 digit outbound call setup?
CCM 4.1 does not allow the + to be assigned as a prefix.
Thanks!
Green
Re: Callmanager - Append + to outbound call CID?
Try applications dial rules...perhaps it helps
but this will affect all ur calls.
Community Member
Thanks for the response. Can application dial rules apply to all outbound calls, or does it only apply to IPMA or webdialer applications? Can't seem to get it to apply to regular outbound calls
126
