06-13-2008 09:54 AM - edited 03-15-2019 11:15 AM
Hi All,
Does anyone know if CDR log gets truncated after a successful BARS backup ?
I am running CCM 4.1.3 sr6a and I do have BARS schedule to run nightly but for some reason the CDR log does not get truncated and I have to manually shrink it atleast once a week to reduce the size.
Has anyone run into this issue ?
Is there a way to get the CDR log truncated nightly ?
Thank you very much !!!
Danny
06-13-2008 10:06 AM
When you select CDR DB in BARS it should be truncated for backups
If it is not u can schedule a Job in SQL or a bat file and activate Schedule tasks service as workaround
06-13-2008 12:40 PM
Hello Gonzalo,
I do have CDR DB selected in BARS for nightly backup. Do you have any ideas why CDR log is not being truncated ?
I am running BARS 4.0.12
Thank you very much for replying !!!
Danny
