Callmanager CDR reporting
is there a way to pull total number of calls for each pri? on cdr reporting
1 ACCEPTED SOLUTION
Silver
Re: Callmanager CDR reporting
Yes, in CDR database. For outgoing calls check field DestDeviceName (you'll have there gateway name, for h323 just IP, but for MGCP there is full PRI name - so you can check interface) and for incoming you can check OrigDeviceName.
regards,
PK
1 REPLY
Silver
regards,
PK
244
