Callmanager Database Definations
Is there a guide or information on CCO for Callmanager Database Definations.
Like there is one for CDR (http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_programming_usage_guide09186a00806556fb.html
BR
1 ACCEPTED SOLUTION
Re: Callmanager Database Definations
This SQL query should work for you. Just run it from MS Query Analyzer. Remember to change the Database name to your current CCM database name. This will return the Device Name and XML parameter for PC Voice VLAN Access.
Enabled PC Voice VLAN query
USE CCM0300
SELECT Name, XML
FROM dbo.Device
WHERE XML LIKE '%0%'
Disabled PC Voice VLAN query
USE CCM0300
SELECT Name, XML
FROM dbo.Device
WHERE XML LIKE '%1%'
Please rate any helpful posts
Fred
Green
No.
Thats not public information, only Engineering internal docs.
Hi Thanks for the reply.
The reason why I came up with this is because, I want to run a SQL query to find no.of phones with "PC Voice VLAN Access" disabled.
USE CCM0300
SELECT Name, XML
FROM dbo.Device
USE CCM0300
SELECT Name, XML
FROM dbo.Device
Fred
Thanks Fred:)
Thats what I was looking for.
243
