Callmanager Express 4.1
mmajai_cisco
Dear All,
I have CallManager Express 4.1, I want to configure one of my extensions (701) to automatically forward the calls to another extension (705) after 2 rings only if no body there to pick the handset of 701
How to do this?
thanx
Adrian Saavedra
Level 7
Level 7
Hi friend,
Take a look in the CME Administration Guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmetrans.html#wp1105062
Hope this helps.
Please rate useful posts.
Best regards,
- Adrián.
Rob Huffman
Hi Majai,
call-forward noan
To configure call forwarding so that incoming calls to an extension (ephone-dn) that does not answer are forwarded to another number, use the call-forward noan command in ephone-dn or ephone-dn-template configuration mode. To disable call forwarding, use the no form of this command.
call-forward noan target-number timeout seconds
timeout seconds - Sets the duration that a call can ring with no answer before the call is forwarded to the target number. Range is from 3 to 60000. There is no default value.
From this good CME doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_c1ht.html#wp1063669
Hope this helps!
Rob
tonyspcrepairs
Level 2
Level 2
I am only a beginner but in your config try this:
#ephone-dn 701
call-forward noan 705 timeout 4
you might need to save the running-config and reboot the router to bring in the change.
Hi Anthony,
Rebooting the router is not necessary for changes to take effect.
Best regards,
- Adrián.
