Callmanager Express : Dial plan problem
ccr_cisco
I have 2 sites interconnected by a H323 trunk. Site A has dial plan 32x site B has 3xxx.
When on site A I want to dial a number on site B with for example number 3257 it will dial 325 in site A. This happen if I dial on-hook or off-hook
Is there a way (without changing dial plan) on CME of site A to not automtically dial the first 3 digit.
Dial-peers are OK if I type "sh dialplan number 3257" it well show the H323 trunk. The problem appears on the dialing phone itself.
Thanks for your help.
Jaime Valencia
Add a site code and dial site code + 3/4 digits
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
