You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Callmanager Express Extension Mobility
Hi all,
Hi have configured EM on CME 8.0, everything is working fine but i have one  doudt that i dont know if sameone can tell me if its possible:
I need to have the same extension for user and logout profile but be able to lock calls from the phone when is on logout.
Is this possible ?
  • IP Telephony
1 REPLY
Re: Callmanager Express Extension Mobility
CME call blocking (toll bar) currently is applicable at device level and
not dn or profile basis.
You may be able to make it work though by playing a bit with after-hours,
login and pin CLI....
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeblock.html
163
