Callmanager Express - Hair Pin Call Routing Not Working
Alright looking for some advice here been running in circles on this issue. Appreciate any input.
Scenario: External caller calls in and rings extension, extension has call forward all to external number. External caller gets fast busy or disconnect (depending on which IOS) 12.4.15T13 (Fast busy), XJ4 (Disconnect).
I've tried having the user call-forward with the full number 1-XXXXXXXXXX  and the regular 10 digit number. Need to find some way to make this work.
Equipment: 3725
IOS: Tried both XJ4 and 124-15.T13
Inbound dialpeer:
dial-peer voice 2 pots
translation-profile incoming autoattendant
incoming called-number 672
direct-inward-dial
port 2/0:23
Outbound dial peer
dial-peer voice 1 pots
destination-pattern 9T
direct-inward-dial
port 2/0:23
Telephony Service:
call-forward pattern .T
Debug of idsn q931 (this is for the redirected call from the extension -> external):
Dec 30 09:31:10.627: ISDN Se2/0:23 Q931: pak_private_number: Invalid type/plan 0x0 0x0 may be overriden; sw-type 13
Dec 30 09:31:10.627: ISDN Se2/0:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Called num 7143962687
Dec 30 09:31:10.627: ISDN Se2/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0083
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9838C
                Exclusive, Channel 12
        Facility i = 0x9F8B0100A117020101020100800F574952454C4553532043414C4C4552
                Protocol Profile =  Networking Extensions
                0xA117020101020100800F574952454C4553532043414C4C4552
                Component = Invoke component
                        Invoke Id = 1
                        Operation = CallingName
                                Name presentation allowed
                                Name = WIRELESS CALLER
        Calling Party Number i = 0x2180, 'XXXXXX1672'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, 'XXXXXX2687'
        Redirecting Number i = 0x000082, '112'
                Plan:Unknown, Type:Unknown
Dec 30 09:31:10.655: ISDN Se2/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8083
Dec 30 09:31:10.735: ISDN Se2/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x8083
        Cause i = 0x8295 - Call rejected
Dec 30 09:31:10.739: ISDN Se2/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x0083
Dec 30 09:31:10.755: ISDN Se2/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8083
Dec 30 09:31:10.771: ISDN Se2/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x86A7
Dec 30 09:31:10.795: ISDN Se2/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x06A7
Dec 30 09:31:10.795: ISDN Se2/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x86A7
Debug of Dialpeer inout:
Dec 30 09:34:16.745: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=9XXXXXX2687, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=9XXXXXX2687
   Result=Success(0) after DP_MATCH_DEST
Dec 30 09:34:16.745: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=1
   Calling Number=, Called Number=XXXXXX2518, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=XXXXXX2518
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Dec 30 09:34:16.749: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
Dec 30 09:34:16.749: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Partial Matches(1) after DP_MATCH_DEST
Dec 30 09:34:16.749: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
Dec 30 09:34:16.749: //-1/46D3C697804C/DPM/dpMatchPeersCore:
Dec 30 09:34:16.749: //-1/46D3C697804C/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1 Dec 30 09:34:16.745: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
Hall of Fame Super Gold
Make sure a valid calling number for the circuit is used. Meaning, a DID assigned the PRI, not the calling number of cellphone.
Also, you should suppress sending Facility IE to telco.
Just to be sure, i'm seeing this go out when the transfer to external number is being made, that number I X'd out is the main number for the site. The telco should be seeing this number attempting to initiate the call?
Do you know a doc where I could look up supressing IE info? would that cause the carrier to drop the call?
You can compare a working, regular call with a failed, redirected call to see what is causing telco to reject it.
You can suppress facility ie with
no isdn outgoing ie facilty
629
