Callmanager Express integration with Ericsson BP-250
I have a Callmanager Express ver 3.3 and I need to integrate it with a Ericsson BP-250 through 4 isdn basig qsig. I am able to integrate it through a PRI Qsig but when I try to do that with basics the interfaces never go up.
This is the configuration:
interface BRI0/0/0
no ip address
isdn switch-type basic-qsig
isdn protocol-emulate network
isdn point-to-point-setup
isdn incoming-voice voice
isdn T310 120000
The router is a 2811. The led card never are turn on.
Thanks a lot.
Best regard.
Re: Callmanager Express integration with Ericsson BP-250
interface BRI0/2/0
isdn layer1-emulate network
isdn send-alerting
isdn sending-complete
isdn static-tei 0
isdn skipsend-idverify
line-power
Check your cables!
Thanks, It work perfect.
I'm glad it helped.
Hall of Fame Super Gold
Just a nitpick, you probably don't need "line-power". That is only necessary to power ISDN phones that have no power supply of their own.
716
