CallManager Express music-on-hold
With CallManager Express, is there a way to remove the on-hold beep tone so the party that is on hold just hears silence?
Re: CallManager Express music-on-hold
I'm not sure exactly why you'd want to do this, but you could just record a few seconds of silence as a ulaw-encoded wave file and use that as your MOH.
Thanks!
I am using CCME. In the config:
telephony service
moh music-on-hold.au
I found that sometimes there is moh, somtimes it only has beep sound.
e.g. when I press the hold button, the other end can listen to music. But if I transfer the call, the other end hear beep sound.
I would like to other end hear Music when I press hold, transfer or conference button (not beep sound). Is there any config i missed?
Thanks.
Bronze
Keep in mind that in older versions of CME, for calls between IP phones on same CME, only tone-on-hold is supported.
MoH was only supported for PSTN calls.
With CME 4.0, a new feature was added to enable MOH between ip phones.
I am using cme ver 4.0.3.
So how can I enable MOH between IP Phone.
Thanks.
Bronze
1113
