Callmanager Express not responding to SIP Request OPTIONS
Our Cisco Call Manager Express IP-PBX box stopped working with our provider today after a long period of service.  Packet capture shows that the CME is not responding to the provider's SIP Request OPTIONS ping packets with 200 OK and thus, the address of the CME box becomes "Out of Service" and no incoming and outgoing calls can be made.
Is there any specific commands that explicitly force the CME to reply with 200 OK from Request OPTIONS?
Please post your config.
Yosh
HTH Regards, Yosh
Hall of Fame Super Gold
Try a reload if you haven't already.
Try reloading...several times. Config posted below:
Current configuration : 22534 bytes
version 12.4
service password-encryption
hostname CiscoCME
boot-start-marker
boot system flash:c2800nm-spservicesk9-mz.124-24.T2.bin
boot-end-marker
logging message-counter syslog
logging buffered 2000000
no logging console
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain lookup source-interface FastEthernet0/0
ip domain name mydomain.com
no ipv6 cef
voice service voip
clid network-provided
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol cisco
sip
   outbound-proxy ipv4:x.x.48.25:5070
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice translation-rule 1
rule 1 /^9/ //
voice translation-rule 2
rule 1 /^xxxxxxxxxx/ /xxxxxxxxxx/
voice translation-rule 4
rule 1 /^xxx948\(.*\)/ /\1/
rule 2 /^xxx884\(.*\)/ /\1/
rule 3 /^xxx957\(.*\)/ /\1/
voice translation-rule 6
voice translation-profile BLOCK
translate calling 6
voice translation-profile CUE
translate calling 4
translate called 4
translate redirect-called 4
voice translation-profile OUT
translate called 1
voice translation-profile voicemail
translate calling 2
voice-card 0
dspfarm
dsp services dspfarm
crypto pki trustpoint TP-self-signed-2647326429
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2647326429
revocation-check none
rsakeypair TP-self-signed-2647326429
crypto pki certificate chain TP-self-signed-2647326429
certificate self-signed 01
username xxxxxx privilege 15 secret xxxxxx
archive
log config
  hidekeys
ip ftp username cisco
ip ftp password 7 045E5F025976666507
class-map match-all VoIP
match ip rtp 2000 16383
policy-map VoIP
class VoIP
  set dscp ef
ip address 192.168.100.253 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Service-Engine1/0
ip unnumbered FastEthernet0/0
service-module ip address 192.168.100.252 255.255.255.0
service-module ip default-gateway 192.168.100.253
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.100.1
ip route 192.168.100.252 255.255.255.255 Service-Engine1/0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
no logging trap
control-plane
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
sccp local FastEthernet0/0
sccp ccm 192.168.100.253 identifier 1 version 4.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register CFB001CF6806720
associate profile 2 register MTP001CF6806720
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 5
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 8
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
dial-peer cor custom
name LONGDISTANCE
name INTERNATIONAL
dial-peer cor list LD-Calling
member LONGDISTANCE
dial-peer cor list INT-Calling
member INTERNATIONAL
dial-peer cor list Block-PSTN
dial-peer voice 7000 voip
mailbox-selection orig-called-num
description Cisco Unity Express voicemail pilot number
destination-pattern 7000
voice-class sip outbound-proxy ipv4:192.168.100.252
session protocol sipv2
session target ipv4:192.168.100.252
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 15 voip
description International
translation-profile outgoing OUT
preference 1
destination-pattern 9011T
voice-class codec 1
session target ipv4:x.x.48.25:5070
dial-peer voice 911 voip
destination-pattern 911
voice-class codec 1
dial-peer voice 7999 voip
description Administration via Telephone Prompt
destination-pattern 7999
codec g711ulaw
no vad
dial-peer voice 7100 voip
destination-pattern 7100
codec g711ulaw
no vad
dial-peer voice 5994 voip
description VM Pilot
translation-profile outgoing CUE
destination-pattern xxxxxx5994
codec g711ulaw
no vad
dial-peer voice 5995 voip
description AA Pilot
destination-pattern xxxxxx5995
codec g711ulaw
no vad
dial-peer voice 5996 voip
description GSM
destination-pattern xxxxxx5996
codec g711ulaw
no vad
dial-peer voice 1011 voip
call-block translation-profile incoming BLOCK
call-block disconnect-cause incoming user-busy
destination-pattern 9(1?)[2-9].........
voice-class codec 1
incoming called-number .
dtmf-relay rtp-nte
gateway
timer receive-rtp 1200
sip-ua
authentication username xxxxxx password xxxxxx
retry invite 2
retry bye 2
retry cancel 2
retry register 10
sip-server ipv4:x.x.48.25
telephony-service
sdspfarm units 3
sdspfarm transcode sessions 16
sdspfarm tag 1 MTP001CF6806720
sdspfarm tag 2 CFB001CF6806720
max-ephones 42
max-dn 50
ip source-address 192.168.100.253 port 2000
auto assign 1 to 10
calling-number local
timeouts interdigit 5
system message xxxxxx
url services http://phone-xml.berbee.com/menu.xml?opts=134567
url authentication http://192.168.100.252/voiceview/authentication/authenticate.do
load 7914 S00105000300
load 7941 SCCP41.8-4-2S.loads
load 7961 SCCP41.8-4-2S.loads
time-zone 8
dialplan-pattern 1 xxxxxx59.. extension-length 4
dialplan-pattern 2 xxxxxx51.. extension-length 4
dialplan-pattern 3 xxxxxx86.. extension-length 4
voicemail 7000
max-conferences 8 gain -6
call-forward pattern .T
call-forward pattern 6000
moh music-on-hold.au
web admin system name cisco password cisco
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
night-service code *99
create cnf-files version-stamp 7960 Nov 28 2011 15:43:12
vm-integration
banner login ^C
^C
line con 0
login local
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
exec-timeout 30 0
privilege level 15
login local
transport input telnet ssh
line vty 5 15
exec-timeout 30 0
privilege level 15
login local
scheduler allocate 20000 1000
ntp server 208.66.175.36
end
Do a show sip-us register status. Have you called your sip provider to troubleshoot? Below is a link that might help you with configuring you sip trunk incase you lost a configuration.
http://blog.alwaysthenetwork.com/tutorials/sip-trunk-with-cme/
Yosh
HTH Regards, Yosh
show sip-ua register status shows all the DID extensions that are registered.  Since our provider did not provide the equipment, all they could tell me is that their Acme Packet is not picking up any 200 OK replies aftering sending out SIP Request Options and consider the line to be"out of service".  Looks like I may have to resort this to a Cisco TAC.  THanks for the help.
I'd like to add that no changes have been done to the CME configuration in over 2 months. The only recent change was in the ASA firewall, disabling the SIP inspect temporarily. The service provider does not uses standard ports and i found out my SIP header was advertising a private IP. I created a SIP inspect for non-standard SIP ports. I wonder if this would have anything to do with this problem?
Yes, firewalls are knows to not handle SIP properly, even if thye claim otherwise.
I agree with Paolo and I would remove the inspect to see if that fixes your issue.
Yosh
HTH Regards, Yosh
1050
