CallManager Express "Busy Trigger"
I would like to configure the "busy trigger" on 2 in CallManager Express 4.2.
The goal is to be able to have the following situation:
When a call is already placed from a phone, if a second call arrives on this phone, an alert is played on this phone to announce the second call (beep).
Using this, the user can place the first call on hold and answer the second call.
The actual situation is that the second call receives directly the busy tone. It's only possible to receive one call on an IP phone. So I would like to change the busy trigger from 1 to 2.
In CallManager Express, I think that this feature is the "call-waiting".
All the "ephone-dn" are configured with "dual-line" and I added "call-waiting beep" (default value) but the second call continue to receive the busy tone.
Here is the configuration of "ephone-dn":
ephone-dn 1 dual-line
number 6600 secondary 155066600
label 6600 - Reception Switchboard
description 155066600
name Reception Switchboard
allow watch
call-forward all 9905
huntstop channel
no huntstop
hold-alert 30 originator
Do you know what is missing in the configuration to be able to receive 2 simultaneous calls on an IP phone?
Thanks in advance,
François
1 ACCEPTED SOLUTION
Green
Re: CallManager Express "Busy Trigger"
Green
In the example from your link, the huntstop channel is still there. Why do I have to remove it?
I also found something else... the button was configured using ":" in the ephone config:
ephone 1
button 1:1
Following your example, I should replace ":" by "c":
ephone 1
button 1c1
Is it correct?
I just noticed that I was wrong... I don't need to change the ephone button layout.
The "no huntstop channel" should solve my problem.
I'll let you know as soon as it will be tested.
The "no huntstop channel" solved my problem.
Many thanks.
602
