Callmanager Express- Siemens Hipath 3000 Q.SIG problem
I have a problem with qsig trunk between Cisco Callmanager express 7.1 and Siemens Hipath 3000.
If the cisco user is calling to siemens, the siemens phone does not display the name, only the number.
From Siemens to Cisco, everything is working fine.
So my question is:
1)what is the default qsig type for CME 7.1 is it ISO or ECMA?
2)how can I change the type from ISO to ECMA and ECMA to ISO
There are several discussions regarding CUCM, but not the Callmanager express.
David
Hall of Fame Super Gold
Re: Callmanager Express- Siemens Hipath 3000 Q.SIG problem
Please take "debug isdn q931" with "term mon".
here is the output of the debug, btw I'm using Callmanager Express, so it's not H.323 GW or MGCP.
Dec 21 15:40:12.424: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 173
Dec 21 15:40:12.424: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0195 callID = 0x8116 switch = primary-qsig interface = Network
Dec 21 15:40:12.424: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0195
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Facility i = 0x9FAA068001018201018B0100A111020201A602010080083137332054657374
        Facility i = 0x9FAA06800100820100A11002010502010080083137332054657374
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Display i = '173 Test'
        Calling Party Number i = 0x0080, '173'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0725540600'
Dec 21 15:40:12.568: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x8195
prov-prh1#
prov-prh1#
prov-prh1#
prov-prh1#
prov-prh1#
prov-prh1#
prov-prh1#
Dec 21 15:40:17.628: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8195
Dec 21 15:40:17.716: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8195
        Progress Ind i = 0xA590 - Reserved value
        Locking Shift to Codeset 5
        Codeset 5 IE 0x32  i = 0x80
Dec 21 15:40:19.900: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8195
Dec 21 15:40:19.904: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 0725540600 N/A
Dec 21 15:40:19.904: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0195
prov-prh1#
prov-prh1#
prov-prh1#
Dec 21 15:40:23.768: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8195
        Cause i = 0x8090 - Normal call clearing
Dec 21 15:40:23.768: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0  disconnected from 0725540600 , call lasted 3 seconds
Dec 21 15:40:23.768: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0195
Dec 21 15:40:23.812: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8195
prov-prh1#
Thank you very much.
David
CME is sending calling number both in QSIG format and regular IE:
Consequently, the problem is on the PBX, you cannot do anything about, you have to ask the PBX technician.
siemens phone is displaying only the number not also the name "173 Test". The Siemens guy is able to configure his PBX Q.SIG ECMA or ISO, do you know which one is better or more usefull for cisco callmanager express? Or am I able somehow to finetune my config?
e.g.
prov-prh1(config)#interface serial 0/0/0:15
prov-prh1(config-if)#isdn supp-service name calling ie 40 profile ROSE  operation-value-tag ?
  ecma   use ECMA OID global value 0x06 04 2B 0C 09 00
  iso    use ISO OID global value 0x06 05 28 EC 2C 00 00
  local  use local value 0x02 01 00
So I'm not sure about the following commands:
prov-prh1(config-if)#isdn supp-service name calling ?
  ie                   name ie value
  operation-value-tag  Specify the operation value tag
  profile              Specify the protocol profile
prov-prh1(config-if)#isdn outgoing ie ?
  called-number       CALLED NUMBER IE in outgoing ISDN messages is allowed
  called-subaddr      CALLED SUBADDR IE in outgoing ISDN messages is allowed
  caller-number       CALLER NUMBER IE in outgoing ISDN messages is allowed
  caller-subaddr      CALLER SUBADDR IE in outgoing ISDN messages is allowed
  connected-number    CONNECTED NUMBER IE in outgoing ISDN messages is allowed
  connected-subaddr   CONNECTED SUBADDR IE in outgoing ISDN messages is allowed
  display             DISPLAY IE in outgoing ISDN messages is allowed
  extended-facility   EXTENDED FACILITY IE in outgoing ISDN messages is allowed
  facility            FACILITY ie in outgoing ISDN messages is allowed
  high-layer-compat   HIGH LAYER COMPAT IE in outgoing ISDN messages is allowed
  low-layer-compat    LOW LAYER COMPAT IE in outgoing ISDN messages is allowed
  network-facility    NETWORK FACILITY IE in outgoing ISDN messages is allowed
  notify-indicator    NOTIFY INDICATION IE in outgoing ISDN messages is allowed
  progress-indicator  PROGRESS IND IE in outgoing ISDN messages is allowed
  redirecting-number  REDIRECTING NUMBER IE in outgoing ISDN messages is allowed
  user-user           USER USER IE in outgoing ISDN messages is allowed
Thank you!
david
Sorry, I should have said that you are sending the calling name also, see the string in hex:
Regarding the settings you mentioned, these are quite obscure, I never had the need to change them. Hope you can find the right combination, good luck!
2245
