callmanager express with pri isdn type 5ess
CAn callmanager express support 5ess call by call? If so, what would have to be coded?
Hall of Fame Super Silver
Re: callmanager express with pri isdn type 5ess
Sure it can, 5ESS is an AT&T ISDN switch-type. I am assuming you have a PRI, in order to configure a PRI with CME, do the following:
1. Define the ISDN switch type in the global configuration.
IOS-GWY(config)#isdn switch-type primary-5ess
2. Configure the T1 controller for ISDN PRI signaling.
IOS-GWY(config)#controller t1 1/0
IOS-GWY(config-controller)#framing esf
IOS-GWY(config-controller)#linecode b8zs
IOS-GWY(config-controller)#pri-group timeslots 1-24
3. After configuring the pri-group command, the D channel (interface serial 1/0:23) and the voice port (voice-port 1/0:23) are created automatically by the router.
4. Configure dial-peers
HTH, please rate all posts!
Chris
Chris,
Thanks, that much I've got but does the 5ess require call by call support
Can you elaborate on "call by call support"?
Chris
Hall of Fame Super Gold
I think that "call by call" is just a market name for ISDN PRI, nothing else.
Sure, isdn switch-type primary-5ess.
213
