Callmanager IP
j.huizinga
Level 6
Level 6
I have a callmanager 7.1.5 and the callmanager is configured with a hostname.
DNS is configured correctly and the phone register correct.
We want to remove the DNS, and this means we have to make the callmanager/phones independent from DNS
Can I just change the server name (system/server) from name to IP and do a reboot?
JH
yahsiel2004
Level 7
Level 7
You will also need to change the Service URLs from a hostname to an IP address. They're found under "Enterprise Parameters>Phone URL Parameters"
Yosh
HTH Regards, Yosh
I know about the enterprise parameters, but for the moment I am only concerned to go from host name to IP address.
Do you have a link or so describing this?
JH
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/install/7_1_2/ipchange/ipchg712.html
Yosh
HTH Regards, Yosh
