08-12-2013 09:56 AM - edited 03-16-2019 06:48 PM
When I enter an IP address of a registered Cisco IP phone in the web browser, I cannot access any phone (7960 or 7962). The error says: "INTERNET EXPLORER CANNOT DISPLAY THE WEB PAGE". The web page access for the phone is enabled under DEVICE-PHONE. Any ideas?
Ron
08-12-2013 10:18 AM
Try this: Disable web access, apply and reset the phone, Enable web access and apply and reset again. This is assuming nothing is blocking the traffic in your network.
Please rate helpful answers!
08-12-2013 10:28 AM
Disabling and Enabling the phone didn't work. There is nothing configured yet that would be blocking the web traffic...
08-12-2013 10:36 AM
Sorry. Disabling and Enabling the phone web access didn't work....
08-12-2013 10:44 AM
Have you tried using a different browser?
Yosh
08-12-2013 11:09 AM
I also tried Firefox & Chrome....
08-12-2013 11:36 AM
Is there connectivity between the networks?? voice and data??
ACLs?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-12-2013 11:51 AM
There are no ACLs as yet. It is a new install. This is the installation from the Network Infrastructure video from the
CCIE VOICE ADVANCED TECHNOLOY CLASS. Everything worked perfectly except for the web access...
08-12-2013 01:55 PM
Hi Ron,
Can you ping the phone from your pc?
Are you sure there is no firewall enabled.
Which version of callmanager do you use?
Check your phone itself:
08-12-2013 04:32 PM
CUCM VERSION 7
My phones are on networks:
177.1.11.0
177.2.11.0
177.3.11.0
My PC and Callmanager are on:
177.1.10.0
The routers at all 3 sites have a route to 177.1.10.0. I can Ping 177.1.10.10 (Callmanager server) but I cannot Ping my PC on the same subnet. There are no access-lists...
08-14-2013 12:52 PM
Thanks to all for your feedback. The issue turned out to be a gateway configuration in the PC itself. Sometimes when you are looking for something, you miss the obvious.
