Community Member
Callmanager Locale Installer 6.1.3
Hi all,
I will upgrade a callmanager to version 6.1.3, for the cco i can download the locale installer for version 6.1.3. This locale is the network or the user locale ?
Re: Callmanager Locale Installer 6.1.3
Community Member
Thanks for your reply.
I notice for user locales the files are the same for diferente phones types (have the same size), do you know if the files are the same or do i need to get one for each type of phone ex. 7911G and 7961G.
It's the same file for each model.  The readme will tell you what phone models are supported too in the locale installer, but as long as the phone is supported it's the same file for multiple phone models.
794
