CallManager MAC Logging
Hello all,
  I was wondering if there is a way for me to log all MAC addressed that are registered into CallManager Express.  If this is possible I would greatly appreciate your service and guidance.
Matt Bowler
Super Bronze
Re: CallManager MAC Logging
Do a show ephone to list all phones
Try filtering the output like so:
Show ephone | i Mac
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron,
  I forgot to mention I am running CallManager Express 4.2(3) on a Wk2 server.
Matt Bowler
Super Bronze
I assure you that you are not.
CME is a part of IOS software, that runs on a Cisco router...
Aaron
You really need to know what you have before asking for help, the title says Callmanager, your explanation CME.
Your version does seem like Callmanager, NOT CME.
CME is for a router
CCM is for MCS servers and runs on Windows.
If you really have CCM use BAT to export all details from phones, this however has no way to show you only the registered phones. There is no report for this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
202
