Community Member
callmanager register into gatekeeper
Dear all
I want to register my callmanager into gatekeeper.
i want that all my ip phone register in gatekeeper like fxs ports
is it possible,, if yes please provide me a link or hint
regards
1 REPLY
Re: callmanager register into gatekeeper
Config in CUCM is fairly easy
Gatekeeper Configuration
Ip phones do not register to the GK, you register CUCM.
If what you're looking is to register phones that are in CUCM as FXS ports in a GK the answer is, no.
If you're not familiar with GKs I'd recommend you to read some of the documentation available on CCO by just searching "gatekeeper"
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
344
