Callmanager service activation
ajkhader123
Hi All,
Recently I installed 6.1.2, after I uploaded the license (2 Nodes), the callmanager service still not getting activated, non of the services are activated,
Unit report it shows Available 2, Units used None, Units Remaining 2....
Normaly once we upload the License the services will get started automaticaly, and thats is the normal way it works, but in my case its different,
Kindly advice,
that doesn't sound right.
stop the services, go to the activation page, check the services to activate, then go back and start the services
does callmanager service shows as running??
are phones registered?
java
if this helps, please rate
java
8 Replies 8
gogasca
Level 10
Level 10
By default CUCM services are deactivated|stopped.
In 6.x we also include SW license.
Licensing is different for triggering service activation. If you dont have the license service will not start which is different..
Do you have all licenses and r u able or not to start the services?
Yes I have all the license and uploaded properly,
are you talking about the services which is under Cisco unified serviceablity,
I am talking about the Cisco callmanager service which is under Service parameter,
and I do not see any start button for the services to start.
So, what's not activated?
You activate all services from serviceability page under tools --> service activation, the first one listed is CM service which provides call processing, is it not started there? There is a checkbox to check and press Activate button.
Chris
Chris,
Under Service Parameter, I see the callmanager services are not activated, and more over it has not utilized the license, with this you can identify the issue,
Herewith I have attached the screen shot of the page, most of the services are not activated.
Kindly advice.
OK, if you go to Service activation, serviceability page i'm talking about, does CCM is activated there???
if you go to the control center is CCM status = running????
to me it seems you just enabled the service but never went to control center to actually start the service
java
java
Under Service activation, none of the services were activated, but under (Control center - Network services) all the services shows Running.
java
java
Java,
I stopped and started the few services including License service, and then started all the services under service activation, now all the services are activated,
Thanks for your Help.....
