CallManager service on the PUB will not start
rhugo
Level 3
Level 3
Hey Gents -
I got a CCM 4.3 PUB that the CallManager service won't start. It seemed to be working OK yesterday, but now I try to reboot it a couple of times, as well as manually restart teh service, with Detailed traces on and all it says is "COM Exception 0" and, in Event Viewer, I see the following error:
Error: CallManager communication cannot communicate with database layer
So, it seems to be DB related, so I am setting Detailed trace for DB as well.
Any thoughts?
Jaime Valencia
check the ODBC connector for the CCM DB, i had a similar case to this while i was at TAC and i had to fix the ODBC to get CCM.exe up and running
java
if this helps, please rate
PATRICK ALAND
Any resolution on this? We're seeing the same error on one of our clusters?
Thanks.
