CallManager Service Stops UCM 7.01
rod.blackie
Just done a 4.1 to 7.0.1 migration and have found that my Cisco Call Manager service suddenly stops after about 1 minute, each time i start it - it stops again after 1 minute.
Anyone else come across this problem?
thanks
Rod
Jaime Valencia
you're most probably missing the feature license. without it you cannot start the CCM services.
if you don't have it get in touch with licensing
java
if this helps, please rate
java
Jaime Valencia
java
java
Java, you are a star! thanks.
My problem was exactly as you indicated, I thought by installing the upgrade licence that it would have enabled all the features... however I didn't think I needed to install the licence that came with the UCM software kit !!
thanks again
Rod
