Community Member
CallManager to CME routing
I have 2 systems working separtly :
- One CME running on a 2821 and a PRI in Canada
-One CM with on gateway and a PRI in France.
As both site are interconnected by VPN I added the Canadian's CME as a H323 gateway on Franch CM to route calls from France to US by the Canadian PRI.
It works for international calls but not for calls to USA.
Here is my confiugration :
voice translation-rule 15
rule 1 /^600\(.*\)/ /011\1/
interface Serial1/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-dms100
isdn incoming-voice voice
isdn calling-number 4166440821
no cdp enable
voice-port 1/0:23
cptone CA
description *** T1 PRIMUS ***
bearer-cap Speech
dial-peer voice 10 pots
17
description *** LOCAL CALL ***
preference 1
destination-pattern 9[2-9].........
clid strip name
direct-inward-dial
port 1/0:23
forward-digits 10
dial-peer voice 11 pots
corlist outgoing call-domestic
description *** DOMESTIC CALL ***
preference 1
destination-pattern 91T
direct-inward-dial
port 1/0:23
prefix 1
dial-peer voice 12 pots
corlist outgoing call-international
description *** INTERNATIONAL CALL ***
preference 1
destination-pattern 9011T
port 1/0:23
prefix 011
dial-peer voice 13 pots
corlist outgoing call-900
description *** 900 CALL ***
preference 1
destination-pattern 91900.......
port 1/0:23
prefix 1900
dial-peer voice 14 pots
corlist outgoing call-976
preference 1
destination-pattern 91976.......
port 1/0:23
prefix 1976
dial-peer voice 15 pots
description *** CALL TO 911 ***
preference 1
paramspace callsetup after-hours-exempt TRUE
destination-pattern 911
port 1/0:23
forward-digits all
dial-peer voice 16 pots
destination-pattern 9911
port 1/0:23
forward-digits 3
dial-peer voice 17 voip
description *** CALL TO PARIS ***
preference 1
destination-pattern 3...
voice-class codec 1
voice-class h323 10
session target ipv4:172.20.65.4
dtmf-relay h245-alphanumeric
dial-peer voice 20 pots
description INCOMING_CALLS
translation-profile incoming TEST
incoming called-number .
direct-inward-dial
port 1/0:23
dial-peer voice 997 pots
description *** DOMESTIC CALL FROM PARIS ***
preference 1
destination-pattern 6001T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
progress_ind disconnect enable 8
clid strip name
direct-inward-dial
port 1/0:23
prefix 1
dial-peer voice 996 pots
corlist outgoing call-local
description *** LOCAL CALL FROM PARIS ***
preference 1
destination-pattern 6001416.......
clid strip name
direct-inward-dial
port 1/0:23
forward-digits 10
dial-peer voice 998 pots
description *** INTERNATIONAL CALL FROM PARIS ***
preference 1
destination-pattern 600T
translate-outgoing called 15
port 1/0:23
prefix 011
From France people have to prefix their international call with 6 to goes out by Canada.
Thanks for your help
235
