Callmanager TOMCAT 96% RTMT
Sarg .
Level 3
Level 3
hello Guy,
has anyone ever encountered this scenario
Processor load over 90 Percent. tomcat (96 percent) uses most of the CPU. Processor_Info: For processor instance 1: %CPU= 99, %User= 99, %System= 1, %Nice= 0, %Idle= 0, %IOWait= 0, %softirq= 0, %irq= 0. For processor instance _Total: %CPU= 99, %User= 97, %System= 3, %Nice= 0, %Idle= 0, %IOWait= 0, %softirq= 0, %irq= 0. For processor instance 0: %CPU= 99, %User= 94, %System= 6, %Nice= 0, %Idle= 0, %IOWait= 0, %softirq= 0, %irq= 0. The alert is generated
Vipul Jindal
what is the call manager version?
are u different version RTMT client?
thanks,
Vipul Jindal
no download the RTMT  from the callmanager  V 7.1.5.31900-3
below is the most common bug related to tomcat in your version
CSCtj50884
Tomcat - java.lang.OutOfMemoryError due to large number of RTMT requests
As a workaround, restart the tomcat service
thanks,
Vipul Jindal
please rate if it helps!!
ok then this is a bug with the callmanager version. i was reading up on that bug and one of the mentioned work around was to turn off RTMT when it is not being used. Does that mean that if RTMT was not being used, I would not get those high utilization levels?
Thanks for all the help
