08-01-2013 11:04 AM - edited 03-16-2019 06:40 PM
Hi All
I am planning to upgrade following components and need help.
Q1: Do we need COP file installation for both upgrade
Q2: Do we need to apply license after upgrade version 9
Thnaks in advance
Solved! Go to Solution.
08-01-2013 11:17 AM
1) yes, covered in the RNs for both products, you need to read them before proceeding with the upgrade.
2) Any PAKS you have, you need to install before the upgrade.
GLO (licensing) will assist on getting the DLUs into user licenses for 9.X
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-01-2013 11:17 AM
java
08-01-2013 12:59 PM
Thanks Jamie,
Is there any suggestion or advise.
Q1: Can I upgrade CallManager to version 9 and Unity stay at current version 8.5 until next maintenance window.
08-01-2013 01:44 PM
Yes, you can upgrade them at different times.
java
