Community Member
CallManager update from 4.1 to 5.1(3)
Can you kindly help us in the procedure of how to get the bootable CD for the 5.1(3) version, i mean after downloading it form CISCO site?
Joseph
1 REPLY
Re: CallManager update from 4.1 to 5.1(3)
All the ones available at CCO are NON-bootable, the site itself has a link that says "For new and full installations - click here to order"
if you want a fresh install order the DVDs
If you have 2 files and want to merge them read the README, all the info is in there
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
114
